fxr 113 mikuni 45 question
i got this bike out of a guys storage since 2002. I took the carb off and sent it to my indie for rebuild. took the tanks off and washed them out until i got all the surface rust and sediment out. put 1 gallon of gas in shook up the tank then let it sit overnight. the next day i drained the water/fuel that was left over out of the tank. i then added 4 gallons of fuel that was sitting in my garage for 1 year {dirtbike gas} Now my bike fires right up on the choke. when i take it off the bike will stutter then die under a light load {1st gear down my street}. would this be a case of bad gas maybe water still in there or carb issue? the damn thing will rev in nuetral but it will eventually stutter and die especially if you lower the rpm less than 1000. any ideas its not the intake boots i already checked for a leak spraying with carb cleaner around the boots.
Pilot jet may not be clear.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
well, the carb could be toast.
a carb is a dirty port devise meaning there are air passages also. some of these ports are very fine but without them, the fuel will not mix or be drawn up. what is bad is that aluminum will bloom (term used to describe the swelling of the metal as it corrodes) and stop up or alter the port and the carb can not work. all the spray in the world can not help.
i used to set the stripped carb in aluma-brite or any other acid cleaner for aluminum and let it set over-nite and then wash it off and blow out every port, sometimes a statue and sometimes a pigeon.
hillside does make it clear that something in the card is blocked.
