Carb kit 75 sportster
Just brought home a 75 iron head sportster and going thru fuel system befofore I try to start! Could see crap in take and previous owner said had running last spring but needs carb work. Fuel was varnish smelling so if it actually ran it had to be very bad! It has the Bendix carburetor and was wondering if anyone has used the rebuild kit from JP cycle?I'm in process of pulling and splitting the tanks as they gotta be flushed and fuel hoses are like concrete! Any replies appreciated!
JP kit probably the same/same as from Drag, Bikers Choice, Tedds.
Large part of a good carb rebuild is to purchase a carb cleaner that you can use to soak overnight.
Napa has a good one with a dip basket.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
glad you brought it up! my can of carb cleaner with Dip basket is dried up! But I checked and got rebuild kit from drag and the kit was much cheaper than JP so it is on the way thank you for your reply Scott!
