VOES 1986 Electra Glide
the VOES on my 86 Electra Glide leaks vacuum and is currently off the bike and in a box on the shelf! New one is not available from Harley! Does anyone Re-make these aftermarket? I have not had any luck finding one and every once in a while especially cold the bike likes to spit and cough until warmed up! I see a lot of replies about rideability spitting pointing at the VOES! Or does anyone happen to have a good used one laying around? Right now the vacuum line is just plugged off at carburetor and the ignition system is all stock! The electric is just unplugged and someone told me to ground the electric but so far I have not experimented with that! Has anyone had any experience totally bypassing and should it go thru a resistor to ground? Any replies are greatly appreciated!
Technically you can use just about any voes from an Evo. Get a vacuum pump and an ohm meter to set the switch to 6.0" hg and you be fine... There is an allen screw at the top of the switch to make your adjustments (under the seal)...
Google "Robs Used Harley Parts" and give him a call.. I'm sure he'll have what you need...
Chester Zielinski
07-10-2015 09:59 PM
