Carburetor issues 42mm Mikuni
I have a 2001 DWG with a 42mm Mikuni carb and it started running rough and when I turned the throttle it hesitated so I disassembled the carb and cleaned it out real well with compressed air. I installed a rebuild kit with a new accelerator pump and all gaskets. When I start it up it runs fine for about thirty seconds then it starts to run rough and acts like it's running out of fuel. I checked the fuel filter and it is clean. I can start it up and give it a little throttle to keep it running then with the throttle position at the same setting it will act like it is running out of fuel then start running normal again. I know it acts like a clogged fuel filter or line but it's not what else could make it run like this?
Thanks.
Jeff
Thanks.
Jeff
Make sure your gas cap is properly vented also.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Received 4,896 Likes
jaystay42
Exhaust System Topics
08-06-2011 08:10 PM
