S&S E or Mikuni 45
What the graph above shows is that while the carbs represented can all breath at different rates, the manifold and heads restrict what they can achieve. The c/v isn't there, but we know it can deliver around 100bhp with the correct parts and set-up. I'm inclined to suggest the choice of carb is more down to how they enhance the ride, rather than their outright performance, as it appears there isn't much to choose between them. It would be interesting to see dyno curves for the same engine with each carb!
Good point. It's interesting that my S&S 107" engine came with a G, yet the later 111" comes with an E. There is plainly an overlap between carbs, but in this case I gather the E gives better low down response than a G, while both carbs can feed their respective beasts at WOT! They have similar numbers on the dyno.
About the same info I found too... With cam and exhaust work, more air should be better?
Now I really haven't looked at the intake manifold? I have even seen any performance ones in looking at carburetors? That would be the best first upgrade in my opinion...
Kind of like a car.. Carb and intake then exhaust and cams..
