Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb identification
Old 01-14-2019, 07:17 AM
Gilad's Avatar
Gilad
Gilad is offline
1st Gear
Default Carb identification
Hey guys,
I've just bought my first HD, its an 1974 XLCH and i'm starting to build it.
I'm not sure what type of carb I have on it, your help will be much appreciated
Thanks,
Gilad.
https://imgur.com/S7DfwsV
https://imgur.com/Ix2scYD
https://imgur.com/4Jrb78r
Old 01-14-2019, 08:59 AM
bustert's Avatar
bustert
bustert is offline
that is not a stock or should i say original item for the 74.
that carb is built by keihin. hd also sold them as a screaming chicken item.
http://sportsterpedia.com/doku.php
here is a site specific for the sportster and has a lot of info including carbs.
Old 01-14-2019, 10:06 AM
Gilad's Avatar
Gilad
Gilad is offline
1st Gear
Is it recommended for my bike? or should I look for the original carb (which is..?)
Thanks for your help!
Old 01-14-2019, 04:52 PM
bustert's Avatar
bustert
bustert is offline
bird in hand so give it a try. the sportsterpedia is a good sorce of info.
hands down the most popular carb for the iron was mikuni vm38 round slide carb. i run one on my 74ch since 1975 and over 175k miles. they are easy to tune and perform well. they are simple and have the best start circuit i have seen and no accel pump for young kids to twist on and flood the engine. i also run the compu-fire ignition with the mechanical advancer. the ultima ignition is a good upgrade and with the timing cup and electronic adv control. i had p cam and 9:1 setup but now run 10:1 and y cams.
Old 01-16-2019, 09:29 AM
Gilad's Avatar
Gilad
Gilad is offline
1st Gear
Thank you for your replies.
In order to get new jets and air cleaner, I need to know what is the specific model of this carb, and for some reason I can't find the exact one with these serial numbers.
Old 01-17-2019, 06:23 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
It looks a much later carb than your bike, which suggests it is worth keeping IMHO. It's H-D part number is on that red label: #27502-86B. The 'B' simply means that it is an upgraded carb relative to when it was originally introduced, which is 1986, as indicated by the -86. If you post that number into a search engine you should see confirmation that it is a stock 1100cc Sportster carb. By coincidence the 1100 was introduced in 1986.
It is unlikely you will be able to get any genuine Harley spares for that carb, but you should find parts, such as a rebuild kit, in the aftermarket.
Old 01-17-2019, 06:57 AM
marcodarq's Avatar
marcodarq
marcodarq is offline
Its the old Keihin non cv performance carb. Properly jetted, they can work very well. Jets are available in the aftermarket if there is no one old enough or knowledgeable enough yo help you at your local H D dealer.
m
Tcmuzzy88
Exhaust System Topics
08-07-2020 12:43 PM
FL-kruzen
08-20-2012 07:48 PM
HD-Dream
12-17-2011 02:32 PM
droff85
Ironhead
03-13-2009 12:02 PM
fxstcguy98
08-08-2008 10:10 PM
Quick Reply: Carb identification
