Carb drain
Carb drain
When shutting down your bike do you turn off the fuel and let the engine run until it runs out of fuel and then turn off the key?
If so, what about drying out diaphragms?
The manual says to shut it down using the kill switch, not the key. Of course, this means you leave gas in the carb.
So, which is it?
TIA . . .
So, which is it?
TIA . . .
RezDuane (02-14-2019)
