Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Evo cv carb tune
Old 04-18-2019, 07:07 PM
Bcoish's Avatar
Bcoish
Bcoish is offline
how did you adjust the mixture screw without removing the air filter housing?
Old 04-18-2019, 07:23 PM
Shem77's Avatar
Shem77
Shem77 is offline
I Use the little flat head bit that goes in my multi drive screwdriver. Its probably about 2 1/2" long, I can reach right up under it all and adjust it easy.
Old 04-19-2019, 08:38 AM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
Commonly that little washer and o-ring for the idle mixture screw is neglected upon assembly. Those went back in, correct?
Also, the small steel tube that goes on the end of the emulsion tube is orientated correctly, yes? It's the steel tube the needle slides into from the carb throat. It's easy to install backwards.
Old 04-19-2019, 01:26 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is online now
Received 1,726 Likes on 924 Posts
Its called a needle jet. Common mistake installing it upside down if it is removed. YD
unregistered436
05-27-2014 12:29 PM
HarleyReece
EVO
20
06-26-2012 06:58 PM
nwpwr22
Ironhead
05-30-2012 03:15 PM
RidemyEVO
EVO
07-31-2010 09:06 AM
csd4682
Ironhead
05-24-2008 11:12 AM
Quick Reply: Evo cv carb tune
