Replacing Petcock - How to Plug Vac
Maybe I had a different problem, but:
I just changed the petcock (to a non vacuum one) on my sporty for a different reason. It's a 2005 so it has a carb. If I let it sit for a month, the bowl will dry out. When I go to start it up, I have to crank the motor long enough for the vacuum pull hard enough to get some gas to flow to fill the bowl. Sometimes it cranks for so long that I start running the battery down. SO now with the regular petcock, I open it, it fills the bowl and will fire right up.
Just switch things over to a conventional non vacuum petcock and a straight shot vacuum line from carb to voes. Makes life simpler. Getting rid of the vacuum activated petcock makes less thing to give you trouble.
Get in the habit of shutting the petcock off every time you shut the bike down and it will become second nature. Won't even remember shutting it off or turning it on. Just becomes part of the shut down and start routine. YD
Take off the seat, LOOSEN front tank mounting bolt a little, REMOVE rear tank mounting bolt, lift back portion of seat up high enough to gain access to said parts. Yes I get it, sometimes I have to do things that I don't want to do also....YD
But He wanted alternatives that would work, He knew how to do it correctly but didn't want too.
I'll put it on my list of things I need to get done......right after I put the cam in my bagger.
Thank you for all the suggestions! I removed the tank over the weekend and fixed it. The cheapest OEM replacement was $92. I went w/ a cheap JP Cycles replacement for now. I'm well aware I get what I pay for, but you gotta do what you gotta do. It works but is super stiff to turn. I hope it loosens up a bit.
bkbroiler (04-12-2019)
Hubone92Sportster
Exhaust System Topics
09-11-2008 11:58 AM
