screamin eagle '88 Harley Davidson Heritage softail
I have that same carburetor and it seems they're as rare as Hens teeth. Mine is on a 1981 XLH1000. I ordered a gasket kit and like yours the only thing that doesn't fit is the float gasket.
I found this thread because I was doing an image search.. This isn't the normal Keihin Butterfly. Its an early Screamin Eagle carb. Mine still holds but it's brittle so I want to change it. Its actually a great carb, and I wouldn't put a newer Venturi carb on it. I'm still looking for the gasket so if I find it, I'll try to keep you posted. I hope you had better luck
Received 5,384 Likes
toemoss
04-25-2007 06:18 PM
liljohnson33
03-07-2007 11:05 PM
