Stock Cams to S&S 509 Cams
I have a 2000 Heritage (28,500 miles on it) with CV carb, stock cams and Vance Hines exhaust. I'm installing S&S 509 cams, new outer and inner bearings, and changing the OEM chain tensioner shoes to Cyco brand. I'm assuming I'll have to increase the jet size on the carb. Should I go 2 or 3 sizes larger and then go smaller by one size after inspecting the spark plugs? I'm trying to avoid a dyno test. I'm the second owner of the bike and I haven't examined the carb yet so I don't know what jets are in there now. Thanks.
Don't disagree with roadmutt but suggest going up say from 175 to 180 on the main; IAW a "half size" up from the current main while you futzing with the needle; start with one .025" SS washer to raise the needle. Avoid Yost or Dyno Jet kits and stick with OEM parts. Consider drilling the vacuum port to 1/8" and installing the lighter spring. This has helped throttle response on the CVs I have worked on. With the needle up .025" and a half size larger main, use that as a baseline for further tuning; better to start a bit rich than lean. You might talk to a local tuner to "buy" an hour of dyno time to check AFR and partial and full throttle. Take a handul of those washer and a couple of larger mains and you can tune the carb in an hour.
Timing could be an issue as the stock timing may be too far advanced for a cam upgrade; corrected compression and CCP are both going to jump up which could result in timing issues. A programmable ignition like the DTT TC88 would be a good idea if it is in the budget. Just pay attention and watch for running hot and listen for ping.
roadmutt (05-09-2019)
I got the bike the other weekend and started taking parts off in prep for the cam swap. I spent about 6 hours the first weekend taking off the gas tank, seat, exhaust and saddle bags. Today I spent about 8 hours removing the valve covers, rocker boxes, push rods, lifters and stock cams. The cam tenioner shoes are getting replaced but I was happy to see that they were both intact. The only potential issue I see is the cam retaining plate (part # 35060-00. It has some scoring and loss of material on the outboard side at the front cam. I only had to press out the bearing for the front camshaft (the rear camshaft would of slid out of the support plate if not for the chain).
