02 Fatboy what carb is this?
I recently bought an 02 fatboy which didnt come with any manuals or build sheet so im needing some help. What kind of carb is this and is this the screw i need to be turning to adjust the amount of fuel getting to the motor. Ive sen some post saying its on the bottom of the carb.
https://cimg1.ibsrv.net/gimg/www.hdf...449c773ab.jpeg https://cimg2.ibsrv.net/gimg/www.hdf...4f6ed03ac.jpeg https://cimg3.ibsrv.net/gimg/www.hdf...a30db0723.jpeg any help would be appreciated! |
Mikuni HSR
Any particular reason you want to monkey with it ? |
It's a Mikuni, get a manual or Google it.
The idle adjustment is done with the black hose that has the end cap on it hanging to the left side. They're the easiest to adjust. |
Issue with starting
After I purchased the bike it rode fine for about 5 rides. I was out prob 2 miles from the house and the bike just dies. So after sitting there for about 10-15min the bike started right back up, i made it home and left it running and it did the same thing, just died. I checked all connections and everything looks good. I took the battery to have it tested; tested good. Replaced the spark plugs, bought 2 crank sensors(haven't installed it yet, was going to do the oil and sensor this weekend). There are no vacuum leaks, cleaned the carb. I think its either a temp sensor or ecu. I watched some videos on testing the coils and they tested good. The bike is a 98ci with all the upgrades internally. Can you tell me what brand of ecu this is? Any help would be great. Thats the reason I thought it possibly could be a carb tuning issue but it was running fine before.
https://cimg9.ibsrv.net/gimg/www.hdf...9f8f31b71.jpeg This has been a little frustrating after purchasing the bike, it is what it is but damn I want to ride. Fortunate the ZX10R is running good, so it hasn't been that bad:) |
Originally Posted by dropmute
(Post 21667425)
After . Can you tell me what brand of ecu this is?
© 2024 MH Sub I, LLC dba Internet Brands
