eager to learn about my super G
I picked up a bike a few months ago with a super G Carb. It's an S&S EVO with edelbrock performer rpm heads hot cams 96 cubic inch. Higher compression but not are what. It runs decent but I know its rich. It has a thunderjet installed. My questions are...... What exactly is a thunderjet? Is it adjustable? Will S&S have details on my engine built 15 years ago, as the PO didn't know specifics? Where is the best place to get info on tuning my Carb to perfection?
I have never tuned before but am not afraid to try my best. Spent plenty of time in the garage too but any pointers are always much appreciated.
The Thunderjet adds another fuel circuit to the carb. Depending on the air bleed jet size in the T-jet it will determine at what RPM the T-jet starts squirting fuel through engine vacuum. More often than not they don't come on until around 4000 rpm or so.
Download a tuning guide from S&S's site. They are very simple to work on. Check with Zippers for T-Jet tuning info and air bleed jets.
Super carbs have a slow or idle jet and a main jet. The newer ones have a main jet air bleed inside the fuel bowl that determines when the main jet kicks which is helpful when tuning as opposed to the old ones that had a fixed main jet air bleed that is not adjustable.
the cool thing about a t-jet is that you can get the low speed (Slow jet) tuned to idle and run clean on the bottom, then tune the main jet to run clean in the mid range, then tune the T-jet for top end performance. The problem with Supers without the t-jet is that there aren't enough fuel circuits leaving you compromising the jetting, generally leaving it too rich in the middle to make up for decent top end jetting.
Timi
10-17-2013 05:55 PM
