Removing clutch hub off 71 shovel
Trying to remove clutch hub off tapered shaft but not having any luck, I have pro clutch so regular puller won’t work. I tried hitting old clutch hub on shaft thread but no luck haven’t tried heat yet any advice would be great !!! |
heat helps with loading the tool on the hub and giving it a wack with a brass hammer is on the table
© 2024 MH Sub I, LLC dba Internet Brands
