2006 American Ironhorse Texas Chopper Air Ride
Old 03-02-2018, 02:42 PM
Bflartey's Avatar
Bflartey
Bflartey is offline
Stage I
Default 2006 American Ironhorse Texas Chopper Air Ride
I have a 2006 American Ironhorse Texas Chopper and i believe the air ride leaks. I bottom out a lot and have to press the button to add more air. It must be leaking out. I read that there is some sort of "neutral" mode that it goes into when leaking to prevent bottoming out but I find that hard to believe. Any suggestions on how to test, tighten, or repair a leak?
Old 03-06-2018, 10:33 PM
67Shuv's Avatar
67Shuv
67Shuv is offline
Start by removing anything in the way of accessing the system components, lines, fittings, solenoids etc. pressure up the system to whatever the recommended max is and spray everything suspected to be leaking with soapy water (dish soap works well) in a spray bottle. You'll find the leak soon enough. Just follow the bubbles.
St Glide
05-17-2016 11:12 PM
Munkee
10-19-2014 12:15 PM
donjuan239459
03-10-2009 04:31 PM
cajunman831
Custom Models
01-16-2007 05:40 AM
Quick Reply: 2006 American Ironhorse Texas Chopper Air Ride
