Can you put a dyna engine in a softail frame?
Old 10-29-2017, 07:37 PM
Wilson321's Avatar
Wilson321
Wilson321 is offline
Stage I
Default Twincam a in a softtail
You need a evo frame and a softtail tranny case . Good thing if u have a 05 or earlier the case is under 400 bucks. And all you tranny guts will bolt rite in. I’ve don’t it. I had a twin cam in a evo softtail frame
You need an adapter plate with oil line set up for the back part of engine case 300 buck, Give or take a few. Good luck. The only difference is I has ordered a SS cycles twincam case with evo mounts.
GOOD LUCK
Old 10-30-2017, 08:41 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,478 Likes on 4,603 Posts
Zombie Thread
Old 12-06-2018, 06:43 PM
LIMike's Avatar
LIMike
LIMike is offline
Looks Great!!!!
Old 07-12-2019, 12:04 PM
Tracy Aanerud's Avatar
Tracy Aanerud
Tracy Aanerud is offline
Stage III
Originally Posted by mfp82393
Anybody tried this one? Using a dyna engine in aftermarket softail frame. I bought a Daytec Goliath RSD softail frame. I haveSuperglideengine. I'mwondering if I can use the Dyna engine and what modifications I wouldhave to make to bolt it in and to bolt up the transmission.
Thanks,
Mike
2005 and earlier Dyna motors can work...there's an adapter plate required that retails for $198 allowing you to use with a 5 or 6speed Evo transmission...then you will also need the appropriate inner primary...I know as my build is just that in a daytec frame
Flufebunekilr
Milwaukee Eight (M8)
101
01-26-2019 11:50 PM
editbrain
09-27-2010 03:40 AM
srl520
09-19-2009 05:02 PM
Dagerazod
12-30-2008 11:25 PM
jimt
01-01-2008 02:51 PM
Quick Reply: Can you put a dyna engine in a softail frame?
