Can you put a dyna engine in a softail frame?
Twincam a in a softtail
You need a evo frame and a softtail tranny case . Good thing if u have a 05 or earlier the case is under 400 bucks. And all you tranny guts will bolt rite in. I’ve don’t it. I had a twin cam in a evo softtail frame
You need an adapter plate with oil line set up for the back part of engine case 300 buck, Give or take a few. Good luck. The only difference is I has ordered a SS cycles twincam case with evo mounts.
GOOD LUCK
GOOD LUCK
Anybody tried this one? Using a dyna engine in aftermarket softail frame. I bought a Daytec Goliath RSD softail frame. I haveSuperglideengine. I'mwondering if I can use the Dyna engine and what modifications I wouldhave to make to bolt it in and to bolt up the transmission.
Thanks,
Mike
Thanks,
Mike
Flufebunekilr
Milwaukee Eight (M8)
101
01-26-2019 11:50 PM
editbrain
09-27-2010 03:40 AM
