My Bobber
On a rigid frame, it is always good to go with mid controls. It gives you more leverage when a big bump is coming your way. Easier to stand up. Just my opinion.
I have been looking for a vintage Chris Craft deck vent for some time, I am going to use it for air cleaner cover.
My oil tank, complements of Curt.
I cut the seat pan out of 3/8 aluminum, it is about 11.5'' x 13.5''.
The seat after I bent it. I cut a 8" pipe in half to make a die for the press, it worked out okay.
I need to pull the front end apart again so I can put a lower cup with a fork stop in and replace the dust caps.
I think I am going to redo the rear fender struts. I am going to cut the strut off and round the fender, then weld some threaded bungs onto the strut so I can remove it if ever need be.
I powder coated the trees in my toaster oven, turned out pretty good. Welded the fender mount bracket which will mount to the frame and oil tank.
The trees before grinding off all the casting marks and the lock tab.
Some other random parts I have cooked in the toaster oven.
The Bad Boy tanks, I thought about staying with the colors but have not decided.
I was going to buy the tanks mounts,but decided to save $40 and make them my self.
The frame fresh from the powder coater.
Nasty legs before the treatment.
Legs after the treatment.
