S100 cleaning
Not buying the same as Simple Green post. I've used the pump spray S100 with great results on rusted chrome on a couple of older Jap bikes and the rust simply vanishes and aluminum looks new. Simple Green does not do that!!! I make sure my bikes are cool and preferably in the shade on a cool day. Lightly spray the bike first with water and then spray a small area on the bike. Let sit a few seconds and micro fiber towel a little if extreme dirt or bugs. Then rinse rinse rinse!!!! You cannot leave any on the surface without possibly having serious issues later. The foam works well also but is even harder to get rinsed off thoroughly.
Received 71,063 Likes
S100 is NOT the same as Simple Green.
I use it, I have used it for years, and it works perfectly. I've used it dozens and dozens of times, on several bikes, and I couldn't be happier.
However, "by the way", I follow the directions.
If you don't rinse it off, it will leave a residue that is difficult to remove. If you do rinse it off, it's awesome.
Been using it for years on a number of different bikes.
Make sure bike is cool, preferable in the shade. I pour some into a small bucket of water .
Spray bike wash with diluted mixture. Work in sections and rinse with a strong flow. The trick is not to let it dry.
After I'm finished rinsing all solution away, I rinse again.
