battery losing Volts, melted pos terminal, no short
07 street bob - so bike wont start turns out pos battery is melted, new battery goes in, went for a ryde, no blown fuses, battery died during the ryde. neg cable looks like its a little warm. tryed to find a short from pos to ground with my meter cant find one. any help? starter relay or charging system problems?
This must be amateur hour...the guy in the video has his meter leads reversed.
The correct connection to the circuit should show the black negative lead on the battery and the red positive lead on the cable...current flows from negative to positive. This is why his current reading is negative instead of positive...no big deal with a digital meter, but do this with an analog meter and it will fry it or blow up in your face.
