What did you do to your Dyna today?
Can't let it go at that... What happened? tp
Location: Depends on who wants to know.........and why.
Received 1,901 Likes
The throttle pull cable is estimated to be shipped on the 24th, so I can get back to work on the Dyna soon. I hope this fixes the idle issue - new cables, properly adjusted, and fresh fuel.
Been tied up with work the last several weeks. But got around to putting the rotors together today. Hopefully get the sprocket finished tomorrow. Once that gets back from the finisher, Ill be about ready to wrap it up. As long as some back ordered bolts get here from ARP.
Was doing a WOT, then at 5500rpms, engine cut off like if i've stalled... and nothing more, no more power/throttle... then few seconds latter (was coasting to stop on the side of the road), engine goes "clac clac clac clac"..
Removed the plugs once home (2 hours later), something seems to have hit the front plug (small impact, and it closed the gap by half), and no more comp on that cylinder...
Will tear it up today, hope the crank is good...
The fork brace on my '13 is a Custom Cycle Engineering TB-2649-1 WG; that's the part number for 49mm fork tubes. Your CVO should have 41mm tubes and would use the TB-2600-1 brace: https://www.customcycleengineering.c...Fork_Trusses-7
Unfortunately that brace is showing unavailable or out of stock at all my usual sources; you may need to contact CCE directly to see about getting one. This brace is absolutely top of the line in quality, fit, and finish. I hope you can chase one down!
finally had a chance to wash it
It has been a pretty busy year for me with home projects and daughter graduating and preparing to leave for the NAVY! so when I had time it was either ride or wash the bike and I chose to ride. I had enough time last night to wash it and bring that '03 gunmetal pearl paint back to life. Its rally week here in Erie so I'm off to See the sites
