What did you do to your Dyna today?
#8891
Put on a 1 1/2" tank lift, washed from top to bottom, and conditioned the leather.
I wasn't sure I'd like the lift but I think the line from the tank to the seat is much better now.
#8895
I used to run a Badlands Illuminator Pro 3. I think it had front run/turn, but can't remember for sure.
Badlands (Namz) and Custom Dynamics are both good. Kuryakyn also sells a couple lighting controllers.
#8896
On a whim I decided to order some 3 watt LED bolts to replace the 1 watters that came with the Delt Fab lever signals. Should be a direct swap. I didn't yet tear the levers apart to verify the thread pitch, but the external dimensions were the same so I'm pretty confident. If not, I'll make them work one way or t'other.
3W vs 1W (both 11mm)
23 lumen vs 10 lumen
Stainless vs Aluminum
180 degree viewing angle vs 60
IP68 vs IP67
ETA...
Tore apart the levers. The 3W and 1W are direct swaps. Delt Fab appears to be using Oznium LEDs...or maybe clones. The one I took out isn't quite as nicely finished as the Oznium I had. Not that it matters. It worked fine. The colorless one below is the Amber that I took out. The yellow one is a warm white I had laying around.
IP68 vs IP67
ETA...
Do you know if yours were version 1 or 2? TIA!
#8897
Honestly don't know, but I just ordered them a month ago. I guess I'd have to assume they are the latest version. They are pretty bright, especially with the 60 degree lens. I checked the current draw and they are definitely 1W diodes. Being a self-diagnosed LED lighting junkie, I have a hard time staying away from the high output diodes... I also like the idea of the wider beam from the 3W diodes; gives me more flexibility with lever orientation without worrying about visibility.
CLTBREAD (02-25-2018)
#8898
Tried to figure out how to change the chirp settings on the Smart Siren. The owners manual lays it all out but just cant get the sequence right to enter the settings menu.
#8899
I’d love the brighter ones... would not look forward to resoldering those tiny wires again. Not hard... but old eyes.
#8900
chris, can you take a pic showing how the wiring is routed on the backside of those levers...thanks
