Head work: 96 vs 103 heads
Old 01-09-2015, 11:41 AM
FXDF619's Avatar
FXDF619
FXDF619 is offline
Default Head work: 96 vs 103 heads
I'm thinking I want to do some head work on my 96" this winter. I was talking to one of my friends who is a mechanic and he said that I should look for a set of 103 heads because they have better springs, etc. I know the 103 heads will bolt right up but my question is what is the real difference between the 103 and the 96 heads. Am I wasting money on buying 103's when I'm just going to have them ported anyways?
For the record I will probably go to 103 or 107 in the future but I want to see how she pulls with head work before I go big bore. I have a Andrews 48 cam, 30t trans pulley and 68t rear pulley as well. Thanks in advance.
Old 01-09-2015, 11:50 AM
Sisu's Avatar
Sisu
Sisu is offline
The heads are the same in the newer models 96" to 103".. Unless there's a badge on the side from SE.. The stock springs are fine for 48's but you already know that if you're running them..
Old 01-09-2015, 12:32 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
I believe the intake runners are little bit bigger in the 103....no point in spending all my the money just to get those heads.
Stick with your and get them ported. Anyway the 48's don't need new springs/heavier springs.
Old 01-09-2015, 01:07 PM
FXDF619's Avatar
FXDF619
FXDF619 is offline
I actually just found a pretty good deal on SE 103 heads. Would that justify buying new heads?
Old 01-09-2015, 01:44 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Here is what I would do before you buy, call a couple of respected head porters and talk to them. WFO Larry, Baisley, etc. They are the ones that get to work with heads day in and day out. Do let us know what you find out!
My bet like HD Bobber, you will save money and sacrifice nothing by using what you have.
Old 01-09-2015, 02:42 PM
HD Bobber's Avatar
HD Bobber
If you are not doing headwork then yes those will flow better, but if I were you I'd add that money into the port job and kick up to the next porting stage and really get the sucker breath'n!
Old 01-09-2015, 06:55 PM
target64's Avatar
target64
target64 is offline
Don't waste your money on those heads find a respectable shop there are a few on this site. and have them do your heads and u will be further off with a better head for less money.
Old 01-09-2015, 07:36 PM
HD Bobber's Avatar
HD Bobber
The consensus is to keep your heads and port the hell out of'em
Hey TARGET, any new plans for the bike?
Old 01-12-2015, 06:56 AM
FXDF619's Avatar
FXDF619
FXDF619 is offline
Sounds like I'll be keeping my heads. Thanks for the help guys. Now I just need to figure out who I'll have do the work...
Old 01-12-2015, 07:24 AM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Here is a place not too far from you:
http://www.danvanceracing.com/index.html
Call 1 or 2 recommended shops and see who you feel comfortable with.
Quick Reply: Head work: 96 vs 103 heads
