Street Bob/Low Rider Air Filter question:
Old 01-16-2015, 10:06 AM
Iceymike's Avatar
Iceymike
Iceymike is offline
Default Street Bob/Low Rider Air Filter question:
I have the 2014.5 Low rider but don't like the look of the air filter. I'm wanting to do some upgrades but with some budget consciousness this winter. I'm pretty sure I've got the exhaust narrowed down, but I wanted to find a way to change the look of the air filter without having to do a full stage 1 upgrade. I've noticed that the street bob has the round bobber style air filter/cover that I would prefer, but am concerned that I don't want to have to spring for the tuner also.
Is the air intake from the street bob an upgrade that would require a fuel tuner when combined with an upgraded exhaust? OR, is it mechanically the exact same as the other dyna stock intakes and just has a different look?
Old 01-16-2015, 10:34 AM
enodrano's Avatar
enodrano
enodrano is offline
You usually don't need a tuner/ecm flash if you only upgraded to a high performance exhaust. If you add a high performance/high-flow air cleaner as well then you will need a tuner/ecm flash. The stock Street Bob filter is not high-flow.I'm not sure if the Street Bob cover will fit your bike or not. If you want to keep the price down look for an aftermarket air cleaner cover that fits your bike.
worked4it
Dyna Parts
03-14-2017 09:50 AM
Jasber
08-24-2016 10:01 AM
Bocephus205
Dyna Parts
06-25-2014 08:35 PM
AussieTX
05-25-2011 05:32 AM
RMBob
08-11-2006 05:31 PM
Quick Reply: Street Bob/Low Rider Air Filter question:
