First 40 miles on new cams and springs
Yesterday was a pleasant 42 degrees around here so I took the opportunity to put the back pack on and do some work errands on the bike.
The loop was around 40 miles with a mix of twisty country roads, some good straightaways and then I jumped on the Interstate for 9 miles to see how the bike fared there.
The twisty's did have gravel still so couldn't really open it up as I was picking lines throughout but I had the chance to hit some decent little potholes as well as stutter type stuff to test out the forks (New springs and Intiminators). Definitely very different from stock. I do think that on the little stuff the forks responded much faster and I felt them far less. As a result I felt like the rear was a little too stiff but that could have been cold weather related or that I haven't been on the bike for a while. I do need to see if I can soften my Works shocks a bit but keep confusing myself on which way to adjust
The Cams (Andrews 57h), VERY VERY cool. First off, no problems with the map that was given to me by V&H, surprisingly no decel pop or any other weird noises (surprising because the canned map for my original set up did have some of the normal popping, etc).
The bike shifted really well, much better with the heavy spring even though I'll have to beef up my hand strength for any type of traffic. I used to have some problems going from 1st to 2nd slipping into neutral, no more!
The acceleration was butter smooth and on a couple of straightaways I hit 80mph in 4th before having to slow down. I assume that my torque may be in the 100 range, I can't even imagine a bike that has much higher. Granted it was my first ride but I had to slow down before I even hit the max of acceleration.
On the Interstate I noticed that my RPM were about 150-200 less in 6th gear (around 2600 at 75mph) than before. Lots of torque when passing but I did drop down to 5th at one point. Also I had left my windshield at home and was wearing my snowboard jacket so speed sustained at 80mph was a little much for me and made passing 18 wheeler's a little freaky.
I couldn't be happier (except now I want a new fairing and new bars), I certainly didn't need the cams or the benefits of them but I am going to enjoy them!
Too bad we got a few inches of snow today with more one the way this weekend, I'm itching to get out even more now than ever.
Nice report Rob, sounds like a lot of fun! Glad you got a solid fuel map for the 57s.
The Works shocks that came to me were set up stiff. Don't remember exactly but the sag was not enough, had to loosen/unscrew the adjuster nut to where only 3 to 4 threads were left on the top side of the nut to get the proper sag - I weigh ~ 185lbs.
I know Works says that they are built specifically for us by weight. I'd say I'm pretty darn close to the end of the nut's adjustment. To be clear though, as I unscrew/loosen the nut, the spring expands which raises the height of the bike but will allow a little more sag correct? This will also soften the ride up a bit?
Yeah, I was kinda surprised that the pre-load was not close. I believe Works builds the shocks from all our info but they do not try to adjust the shocks prior to shipping.
Yes, loosening the adjuster nut will increase the height a bit but you have to dial in the sag to about 1 1/4". I did it by myself but a helper would make it easier and more precise. Just need a tape measure and measure before and after sitting on bike.
No, do not lift bike, just measure first on side stand then sitting on bike: take a look on the bottom of pg 3:
https://www.dropbox.com/s/dxt25a1f20...stall.pdf?dl=0
Not sure if this link will work for you...
No, do not lift bike, just measure first measure on side stand then sitting on bike: take a look on the bottom of pg 3:
