Fuel pump will not come on
Ok so I just finished putting my bike back together, I did 14 inch apes, cable/wire kit, Tank lift, exhaust, intake and a power vision tuner.
I have double checked my wiring still cannot get signal to the pump, I Have my constant just no signal that the run switch has been turned on.
Another issue I am having is the power vision powers up, and I go to load tune and it says it cannot detect a ecm. Is there a chance that the fuel pump is ran off the ecm and this is where im having issues? any relays to check?
Un plugged them, pulled the white part out pulled wires, wired in new color cordinating like I was supposed too. Ran new wires down, put them in the plug to cordinate with the female side of plug and plugged them in.
Also, all switches work besides the run, I am getting power to the switch and out but no signal to the pump only constant when the key is on
gmorris0562
08-17-2013 03:01 PM
