2009 FXD questions
Old Jan 27, 2015 | 05:32 AM
ATGWS's Avatar
ATGWS
Stage IV
Default 2009 FXD questions
New to H-D's and have a few questions I'm sure someone around here ca answer.
1) How good is the fuel injection on the '09 FXD ? Is there patches or fixes needed for that yr model?
2) I've been told that the "X" in the model lettering denotes the smaller forks but the '09 FXD that I'm looking at appears to have the larger forks ?? Does a custom or other model come with the bigger forks stock?
3) The FXD has forward foot controls on foot pegs, can you put floor boards on an FXD ?
Thanks for any info provided.
Andrew
Old Jan 27, 2015 | 05:43 AM
hd4evr2008's Avatar
hd4evr2008
1. Fuel injection works very well. Your bike has 02 sensors.
2. The "X" came from the original model in 1971. The "F" is for the touring bike frame (FLH), and the "X" is for the Sportster forks (XLH). Your bike has 49mm forks. They went larger in 2006. Same as the others.
3. Yes.....you can put floorboards on an FXD.
Old Jan 27, 2015 | 05:48 AM
CJeep's Avatar
CJeep
Just fine. No problems, but like all FI recent vintage lean from the factory for EPA reasons. Many if not most here, go at least stage 1, pipes, intake, and a tune. With an add-on tuner, and those bits, you will really wake up a bunch of unused power.
They are small compared to other models outside the Dyna line. You have 49mm forks with and 09, fatter than the pre-06 models.
Yes, Google Dyna floorboard, or even FXD floorboard. Unsure if the moco makes them, but aftermarket for sure.
Andrew
Good luck with it.
Old Jan 27, 2015 | 07:57 AM
ATGWS's Avatar
ATGWS
Stage IV
thx guys I'm sure I will have more questions as time goes on......
Old Jan 27, 2015 | 08:57 AM
hd4evr2008's Avatar
hd4evr2008
Not really......the other bikes, except Sportsters, have 49mm forks too. They just have them covered up, so they appear larger, but underneath the covers, they're the same size as the FXD..
Old Jan 27, 2015 | 09:20 AM
CJeep's Avatar
CJeep
I guess I really meant the spacing between the forks. X is for narrow, touring bikes have different spacing between the forks.
Old Jan 27, 2015 | 01:02 PM
hd4evr2008's Avatar
hd4evr2008
Ahhh........OK................just misunderstood you!
Actually "X" is for Sportster front end.
Here's a break down of HD letters:
Harley Davidson Motorcycle model designator letters are explained below..
X - Sportsters. These descend from the K series, 1952-56
XL- Series started in 1957. They are "unit construction" (engine & transmission share a common case)
L - High compression (7.5:1 in 1957)
H - Starting in 1958 came the XLH, meaning Higher-power or High-compression (9:1) or Hot .
C - Also in 1958 was the XLCH. The C was intended to mean "Competition".
CR- Cafe racer style, with bikini fairing.
LT- Touring, with bigger tank, thicker seat, and hard bags.
The first letter of the model designator reveals the engine series:
G - Servicar three wheeler, 1932 to 1972
E - Overhead valve 61 cubic inch "big twin" (Engine/trans separated)
F - Overhead valve 74,80 or 88 cubic inch "big twin"
FL - 80 to 96 cubic inches or higher Evo or TwinCam engine and a fat front tire.
K - Side valve 45 and 55 cubic inch sports bike that replaced the WL in 1953 and was replaced by the Sportster in 1957. It had many design features that were carried over to the Sportster.
U - Side valve 74 or 80 cubic inch "big twin"
V - Side valve 74 cubic inch made prior to 1936
W - Side valve 45 cubic inch made 1934 to 1952
X - Sports and special construction. Applied to 1918-1922 opposed twin Sport, 1944 military opposed twin, and 1957 to present Sportster.
The second letter of the model designator reveals the Front end (except sportsters)
X - Narrow tire and sport forks.
L - Wide front tire and Hydra-Glide front forks.
(FX originally meant "Factory Experimental" The first one was the Super Glide FX)
The third letter of the model designator reveals the frame style:
D - "Dyna" frame (with the rubber mounted motor)
HT - "Highway Touring" frame
ST - "SoftailŽ" frame
The next letter(s) indicates the model bike within the frame family:
A - Military (Army) version (except GA, Servicar without tow bar)
B - Battery start (early models), Belt drive (early 80's) Black paint.(1995-6 model, the Bad Boy)
C - Classic, Competition, Custom, various others meanings.
D - Dyna, the newest frame and engine mount design.
DG - Disc Glide
E - Electric start
F - Foot shift (when the standard was hand-shift) and now "Fat BoyŽ"
H - varied between High performance and Heavy duty.
I - Signifies Fuel Injection.
L - Big fat front tire
LR- Low Rider (though many Low Riders don't include LR in the model ID)
N - Nostalgia
P - Police version
R - Rubber mounted engine (some models) racing version (other models)
ST- Soft Tail, SoftailŽ
S - Springer
S - (without following T) Sports version
T - Touring
WG - Wide Glide
X - Sportster or sportster-type front end and Skinny front tire
Mynamejeff
May 19, 2015 03:28 PM
mmcmullin
Mar 21, 2012 05:31 PM
asm481
Apr 2, 2009 09:08 AM
Sonny's World
Feb 22, 2009 11:45 PM
gmpm5754
Feb 7, 2009 12:31 PM
