Ness fairing mounting troubles on a narrowglide. Help?
Ok, so I have searched the hell outta this forum, and for the life of me I cannot find one good writeup with pictures as to how people have mounted this Ness fairing on a narrowglide front end. I know its been done, and I have already determined that the stock "hardware" they give you , is a joke, and probably why these fairings get such a bad wrap for cracking at the mounting points.
I know alot of guys have used the turn signal relo kits, and some fork clamp brackets. I ended up ordering a nice set of four chrome H-D quick disconnect windshield 39mm clamps. Has anyone mounted one of these up with 4 points, using some kind of fork clamp setup?
honestly any decent pics of anyones mounting hardware other than the retarded stock setup would be a big help. Thanks ahead of time, I'm really scratching my head here.
Not sure if this will help you
https://www.hdforums.com/forum/dyna-...headlight.html
Also, seems like the Ness mounts similar to the rifle roadster? I could be wrong though but if it does, there are several threads with guys mounting using the quick release. Like this one - https://www.hdforums.com/forum/dyna-...installed.html
I dunno if any of these will help but might give you some ideas.
