Lucas in Transmission?
Old 05-02-2015, 03:17 PM
LunaticFringe's Avatar
LunaticFringe
LunaticFringe is offline
Default Lucas in Transmission?
I put a bit of lucas in my tranny with HD formula oil & today checked it after 2000 mile and I notice there is a white foam floating to the top.. It doesn't seem like a big deal, the formula oil is pretty thick oil anyway... I'm going to let it ride. It says right on the Lucas bottle to use 25% in transmissions. I won't add it next time though.
has anyone else tried lucas in the transmission?
Old 05-02-2015, 03:26 PM
daveblank's Avatar
daveblank
daveblank is offline
Mine has the Bel Ray tranny fluid & it does the same thing.
Old 05-02-2015, 04:58 PM
PTSDBob's Avatar
PTSDBob
PTSDBob is offline
Gearbox
Valvoline Gear Oil
85w-140 22oz
Old 05-02-2015, 05:18 PM
upflying's Avatar
upflying
upflying is online now
Received 25,992 Likes on 11,040 Posts
What's the reason for adding Lucas?
Old 05-02-2015, 08:12 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
Originally Posted by PTSDBob
Gearbox
Valvoline Gear Oil
85w-140 22oz
This right here Except my '13 Wide Glide needs 29 ounces to fill her transmission, the old 5-speed girls loved it too...
Old 05-02-2015, 08:27 PM
Ape_Hanger's Avatar
Ape_Hanger
Ape_Hanger is offline
I don't understand half the stuff people do on this forum.
Old 05-02-2015, 08:41 PM
ReversePolarity's Avatar
ReversePolarity
ReversePolarity is offline
Foam pretty much means there is air being created in the fluid, you have two oils that are not mixing or not very compatible, in a nut shell you have air pockets between the gears of the trans ~ not good.
Drain it and put in the proper fluid with no additives, if you use a good syn fluid you don't need anything extra.
These slick 50 type additives are old and outdated with today's oils.
IMHO of course, company's that sell that crap may have a different opinion
Old 05-03-2015, 12:52 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
THAT, makes a ton of sense!
Old 05-05-2015, 01:14 PM
Jetbob's Avatar
Jetbob
Jetbob is offline
What He Said.
Old 10-02-2016, 03:32 PM
1stultradpd's Avatar
1stultradpd
1stultradpd is offline
6th Gear
Lmao! Yeah my bad guys! I'm still trying to figure this out, and I don't know how I even put it in that topic area. Sorry men, but thanks a bunch!
smithbrl
12-25-2011 03:57 PM
cruzmisl
09-06-2010 12:24 PM
Mark g
05-27-2009 09:56 PM
Quickie
08-25-2008 04:33 PM
mulch63
Oil Archive (no new posts)
03-31-2008 01:39 PM
Quick Reply: Lucas in Transmission?
