FXDF with Harley Dyna floorboards
No worries. Thanks for getting back to me.
I did order the HD footboard set for my '04 WG. I think I've seen others with same year and older be able to install them on theirs, so I'll give it a shot once the weather breaks.
I've mentioned in a couple of other threads that I recently picked up a very lightly used '15 Fat Bob. It has H-D floorboards already installed by the prior owner, and is also running non-stock, but very quiet H-D pipes. I think that the FXDF stock pipes were probably not compatible with the floorboards, although perhaps they could have been modified to work, but apparently the former owner or dealership decided to swap them for pipes that fit.
Anyway, I'm looking at getting some different pipes. I realize, however, that I'm going to have to be careful of fitment issues. I initially was not happy that the floorboards were on there, had never ridden a bike which had them, but find that I really like them a lot and plan to leave them.
Hi, just waking up this thread in hopes that somebody somewhere has found a set of floorboards that are straight bolt on for the FXDF with stock pipes. I have the 09 and i am trying to avoid changing the pipes. I am very close to fabricating my own brackets.
https://www.hdforums.com/forum/dyna-...l#post16456503
floor boards on dyna
pictures attached. stock hd stuff but yes i had to modify the back right side support bracket to curve around pipes. cut out most of it and made it wider and a bit lower to retain strength. i`m close to 190 and i can stand on it with no problems. and i love them, pegs are for kids!
https://www.denniskirk.com/wyatt-gat...rd/4901395.sku
