FXDF with Harley Dyna floorboards
Did some research and couldn't get a definite answer on whether I could install Harley's Dyna floorboard kit on my bike or not, I have the forward controls and Vance & Hines longshots. Called a couple of dealerships, two said it wouldn't work and one told me he asked a tech and the tech said it was a complete bolt on no modification install. I wasn't exactly trusting this so after being reassured that I could return the thing if it didn't work out, I went ahead a pulled the trigger.
Turns out that it was a pretty simple install, although not quite bolt on, it wasn't that hard.
After laying out the parts and seeing what I had to work with, I learned that the shifter side was going to be a simple bolt on installation so I turned my attention to the brake side. The rear mount wouldn't clear the pipe so I took the pipes off and started hammering the area where I needed clearance. All I had was a wood hammer so it's not the prettiest thing but I went slow so I didn't butcher it too bad. Once I had the pipes back on the bike and the rear mount installed I cut the shield for clearance. I had to do this a couple of times and the thing moved on me once I tightened it but it's all under the floorboard so it doesn't look too bad. Onto the pics:
All I can say is it feels like a completely different bike, did about 400 miles this last weekend and was a lot more comfortable even with the stock seat. If you have any questions feel free to ask.
If you install the vtwin-man FXDP floorboards, you will actually gain a good amount of clearance. And they are straight bolt-on.
Nice little fix on the brake side.
I was just starting to change from mid controls to the floorboard setup on my 2008 FXD tonight. I noticed in the instructions that the brake side floorboard is to be mounted to the brackets at 5-6 ft-lbs and the shifter side says 15-20 ft-lbs. Wondering why the huge difference. Does this sound familiar to you?
Harley neglected to include a tower gasket and shifter spring washer in my kit so I'm at a standstill at the moment and was reading the install instructions out of boredom.
Anybody have any ideas on this?
Thanks
Thanks
