Lost oil putting new derby cover on
When I changed my derby cover on its kick stand I lost most of the oil for my 2011 Fat Bob, where do I put it back in at and what type of oil, obviously I'm a beginner! As I keep reading I guess I need primary fluid for the chain case. So what kind of fluid do I need, how much and where do I put it in?
How did you manage to do that? When the derby cover comes off you shouldn't hardly lose barely any at all. Since you're a Noob,they make a HD funnel for filling it back up properly, part#63797-10. There are various options for what type of oil to refill it with. Try the search feature up at the left corner.
Yep... I use a 3/8" piece of wood under the jiffy when I remove the derby to adjust the clutch, it's enough to keep the fluid in place.
The primary holds 32 ounces , if you've lost a portion of the fluid and don't know what fluid was used I'd drain it all and start again. I use SAE 30, you can use 20w-50 or even that nasty HD Formula + if you'd like but I agree, the owners manual is your friend.
You can find an assortment of how-to videos on YouTube to walk you through the process of replacing the primary fluid...
I picked one of these up from HF a month ago or so, used a 20% off coupon so it was only 40 some odd bucks, you just can't beat that.
Makes some things so quick and easy to do, would suit a task like this perfectly.
http://www.harborfreight.com/motorcy...ock-97843.html
Sigh. You don't have to buy a $60 service manual just to change the fluids. Its in the Users manual that comes with the bike.
OR here:
https://www.harley-davidson.com/cont...rs-manual.html
(So I don't get flamed) If you decide to work on more than the normal fluid maintenance, then yes, the service manual will be a good investment.
OR here:
