CGGorman's 99 Wide Glide build thread
#1202
#1203
#1204
#1205
#1206
The holes will serve as both tool engagement (spanner) as well as locking (either set screws or safety wire).
Thank you! I fancy myself a jack of all trades. That means too many costly hobbies and ideas, unfortunately.
#1209
#1210
Weighed the swingarm.
arm & bearings = 8.5lb (Brocks 10.9lb)
3/4 axle & blocks = 2.4lb (Brocks 2.85lb (1" axle))
No idea what the stock setup weighs yet but Brocks claims theirs "shed(s) 50% of unsprung weight vs OEM swingarm". The swingarm isn't easily split into sprung and unspring sections. They may be using the whole thing or just the small portion aft of the shock mounts. No idea.
