Notices
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, FXR Super Glide, Dyna Glide Convertible, Super Glide T-Sport, Dyna Glide Police, Dyna Switchback, Low Rider, Street Bob, Fat Bob and Wide Glide.
CGGorman's 99 Wide Glide build thread
  #1301
Old 05-11-2019, 03:02 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 1,967 Likes on 1,492 Posts
Extruder (E axis) in place. Lots going on here. All metal extrusion head from E3D England. Dual hob drive from Bondtech. Fans from Noctua. The prox sensor is for z axis homing and level calibration. There is also the LDO motor, a heater and a thermister.
natedog_37 (05-13-2019)
  #1302
Old 05-11-2019, 04:34 PM
cggorman's Avatar
cggorman
cggorman is offline
Old 05-11-2019, 05:32 PM
cggorman's Avatar
cggorman
cggorman is offline
Heated bed is on and most of the wiring is routed.
Max Headflow (05-11-2019)
  #1304
Old 05-11-2019, 11:32 PM
cggorman's Avatar
cggorman
cggorman is offline
...and we're printing...
After some playing around I'll dig into the details and start tuning.
  #1305
Old 05-12-2019, 01:06 AM
cggorman's Avatar
cggorman
cggorman is offline
Not too bad considering I haven't done any tuning yet.
  #1306
Old 05-12-2019, 09:30 AM
cggorman's Avatar
cggorman
cggorman is offline
The following 3 users liked this post by cggorman:
Davdoodles (05-12-2019), Jay Guild (05-12-2019), natedog_37 (05-13-2019)
  #1307
Old 05-13-2019, 09:37 AM
natedog_37's Avatar
natedog_37
natedog_37 is offline
Senior Rider
Very cool. I so want a 3d printer. One day.
  #1308
Old 05-13-2019, 10:31 AM
cggorman's Avatar
cggorman
cggorman is offline
1st technical print...
This is a cooling fan shroud for the printer. I was not happy with the provided cooling fan shroud. This part was printed using a .4mm diameter nozzle with a .15 mm layer height using the provided PLA filament. The part is about 1 1/2 inches across and maybe 3/4 of an inch tall. It would be nearly impossible to injection mold due to the internal cavities that direct cool air onto the printed part.
It's not perfect. I am fairly happy with the quality but I still need to work on some settings. There are several pieces of software that I am still learning.
  #1309
Old 05-13-2019, 04:06 PM
cggorman's Avatar
cggorman
cggorman is offline
So, these are the playtime pieces I printed (ignore the stone skull) next to a water bottle for size reference.
The dragon took about 7.5 hours to print and did so while slept. Being tall and thin, I was curious how it would behave but (not unexpectedly) it finished without issue.
I did initially have a problem with one sensor (IR filament sensor). Some googling turned Up a workaround so the first couple prints were done without that sensor but it is required for some planned upgrades so after a bit more googling and five minutes of diagnosing, I uncovered an error on my part. I plugged it into the wrong port on the mainboard. Once corrected, the printer ran as designed....automatically monitoring filament presence & motion and easing filament loading and unloading.
I'm now quite confident in the printer mechanically.
Nevertheless, it's time get serious. I have a raft of mechanical upgrades planned... Automated multi-material filament changer, heated build chamber, all new printed parts in high-temp plastics, larger and stiffer frame in aluminum extrusion, relocated electronics (outside the build chamber), assorted extruder improvements to handle carbon fiber and higher temps (tool steel nozzles, copper heater block, better heater, etc.)....
I have also arranged for some destructive testing of printed samples using an assortment of engineering-grade filaments from 3DxTech.
  #1310
Old 05-15-2019, 09:16 AM
cggorman's Avatar
cggorman
cggorman is offline
Put together a quick chart of physical properties fpr some filaments I'm comparing. It's hard to read, I know. I suck at charts.
Still have to order some samples and print samples for testing but the carbon fiber filled polycarbonate looks like a winner.
Also ordered some general purpose filament for prototyping...a high temp clear PET for lens trials that should let me evaluate geometry for light pipes/light shaping and a couple other opaque filaments for general use.
Most of the parts I plan to make need to handle high temps so I also got the necessary extruder parts to support that along with a selection of nozzles from .15mm to .6mm diameters.
Quick Reply: CGGorman's 99 Wide Glide build thread
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
