Notices
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, FXR Super Glide, Dyna Glide Convertible, Super Glide T-Sport, Dyna Glide Police, Dyna Switchback, Low Rider, Street Bob, Fat Bob and Wide Glide.
CGGorman's 99 Wide Glide build thread
  #1311
Old 05-18-2019, 04:20 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 1,967 Likes on 1,492 Posts
Print-in-place clearance test. Still tuning but I've got it down to .2mm (.008") clearance. Probaly closer to .15mm (.006"). Print-in-place is a bit bigger clearance than printing the parts separate due to the hot filament welding to close adjacent walls.
Printing a hard case for my 3D mouse right now. It's not a great design (not mine, BTW. From Thingiverse cause I'm lazy) quite a bit chunkier and less graceful than I would design but it'll work.
In progress. 3D gyroid infill. .4mm nozzle and .2mm layer heights. Printed threads.
  #1312
Old 05-18-2019, 04:36 PM
F86
F86 is offline
Printed threads... That's really cool!
Very much enjoying the progress.
  #1313
Old 05-18-2019, 05:26 PM
cggorman's Avatar
cggorman
cggorman is offline
A 5 minute vid of the printer running this part. Silent (other than printer) so you can hear the machine. It's about 53dB (A-weighted) at 12" running in normal mode. There is also a silent mode, but I don't see the need.
  #1314
Old 05-18-2019, 09:42 PM
SixDD's Avatar
SixDD
SixDD is offline
Received 1,261 Likes on 826 Posts
The Mad Genius Scientist - I love it! Keep them coming!
  #1315
Old 05-18-2019, 10:12 PM
cggorman's Avatar
cggorman
cggorman is offline
All done. Perfect fit. Threads are nice but needed a bit of Teflon lube to keep from galling.
It's not a great design. Really bulky and the cord storage is awkward. I may design a clamshell like I originally had in mind. I have this mouse knocking around in my bag constantly and need the protection but I also want it compact amd easy to use. I'll give it a week or two...
  #1316
Old 05-19-2019, 07:33 AM
Frédéric CM's Avatar
Frédéric CM
Frédéric CM is offline
Nice work !
  #1317
Old 05-19-2019, 06:16 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 1,200 Likes on 1,035 Posts
Good work ... Nice to see it as a "finished" part or least see threads on the lower section now
  #1318
Old 05-19-2019, 07:27 PM
cggorman's Avatar
cggorman
cggorman is offline
Doing some fine tuning today... Tedious, but necessary for the best results.
Dimensional accuracy is about +/- .03 mm. Mostly working on cosmetics now.
  #1319
Old 05-19-2019, 09:42 PM
multihdrdr's Avatar
multihdrdr
+/- .03mm ... really?
yeah, I would think you could probably call that pretty good
  #1320
Old 05-19-2019, 09:53 PM
cggorman's Avatar
cggorman
cggorman is offline
I haven't gone bigger than 40mm...yet...but, yeah, a cube measures within .05mm in any direction and is perpendicular/parallel. The last couple hundredths is coming from some minor overshoot at the corners. I'll tune that out. If I measure across flats, avoiding the corners, they average about .03.
There are hundreds of variables that can be adjusted so it takes a while to find the right combinations and values.
Right now I'm still working with the .4mm nozzle. It yields a single-wall thickness of .45mm at a .20mm layer thickness. Ideal layer thickness is 50-60% of nozzle diameter. I also have nozzles for .15, .25, and .60.
Quick Reply: CGGorman's 99 Wide Glide build thread
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
