Do I need a PV? vs. Micro tuner
Improvement? Yes. A 400 dollar plus dyno fee improvement? Everything else staying the same? My opinion, no.
I would not be planning on a dyno tune. Maybe cams or a 107 kit in next few years. Other that that, for now wondering if it would be a good improvement to be using the O2 sensors with the PV. Really like the E-series 2 into 1 as well.
Now, IF you did cams and the 107, THEN it would be required, so that's a moot point. Just an exhaust change, you can have your Micro updated for that.
I'm the guy that says if it works, don't mess with it though. I ran the Micro until I had the motor done and never had an issue with it. YMMV.
Received 2,189 Likes
pv uses O2 sensors if you tell it to. it's on of the most versitle tuners on the market and best long run value since you can move it between bikes. there are others like cobra and FP3 too. all have positives and negatives
glide_n_around
10-01-2013 02:44 PM
