Speed and Gear
Old Jul 6, 2016 | 03:53 PM
adm's Avatar
adm
The thing is, these bikes actually love higher revs.
I try to keep mine in the 2500-4000 rpm range for the best response most of the time, although 5K shifts are not uncommon as my setup really like the higher revs. I don't ever worry about speed for shifting - just listen to the engine instead. They sound really, really good at 4K+ rpm :-)
But for chugging around town - probably the 2-3K range.
Old Jul 6, 2016 | 03:59 PM
cggorman's Avatar
cggorman
I've never put a tach on mine. I don't know what it idles at! I really need to get an inductive pickup for my DVM so I can at least set the idle safely. I've heard the Twin Cam oil pump doesn't do well at potato speeds.
Old Jul 6, 2016 | 04:58 PM
TinCupChalice's Avatar
TinCupChalice
Honestly it doesn't. I've played with the idle using the Power Vision, monitoring my oil pressure gauge at a -100 there's no change to oil pressure at idle. At a -150 you'll see a reduction in oil pressure; at -200 the oil pressure barely registers on the gauge; needle won't hardly budge. At a -100 my Wide Glide idles 840 - 940 RPM with no drop in oil pressure but go lower, and it's a fools errand...
Old Jul 6, 2016 | 06:15 PM
cggorman's Avatar
cggorman
That's too bad. I like to peel potatoes at idle. Guess I better get right on that. I bet mine is idling around 600 right now. Just by ear.
I like data tho. Thanks!
Old Jul 6, 2016 | 10:14 PM
NorthWestern's Avatar
NorthWestern
That is good info. I set mine with the PV at 940, it sounds the best with these cams. My wife HATES it. I am going to have buy a better seat if I idle too much with her on the back
Old Jul 6, 2016 | 11:49 PM
bigbadpoppa's Avatar
bigbadpoppa
Wow u guys gear high. 60mph I'm still sit ting cozy at 3rd. I don't ever get into 3rd gear in the city. At a brisk hwy pace I'm still only on 4th gear.
5th only ever kicks in if I'm just ripping it home before a rain cloud catches me.
I sit at 3500-4000 rpm cruising.
6th gear is as lonely as my divorced wife. I never go there.
Old Jul 7, 2016 | 03:19 PM
apblingAEW's Avatar
apblingAEW
I'm about the same. 2300+. anything below and she get grouchy on my 09 fxdf. 70+ for 6th gear, so I rarely use it. I never had a tach until recently and was actually surprised how high of rpm the bike and I both prefer. And nots not for hot roddin' around - I can just feel and hear the bike prefers it.
The wife has a 15 fxdb that seems to be more tolerant of lower rpms. I can get it into 6th easily around 60-65. Her exhaust is also much quieter, so at faster speeds I'm relying way more on feel than I am feel and exhaust note.
Old Jul 7, 2016 | 03:40 PM
TinCupChalice
That 'feel' of upshifting and downshifting we talk about constantly has so much to do with the alignment of the bike; the Dyna is a unique beast in the HD world and lives and dies by that alignment. I've owned several Dyna's and each was different in that 'feel'; I've got this 103" dialed in to the point I can do 'put me in cuffs and impound the bike' speeds on the big sweepers following Lake Michigan; it's the alignment that will give you that upshift/downshift sensation. Go with it, each of these beasties are different, and that's why they're the greatest bikes HD ever built
Old Jul 7, 2016 | 04:27 PM
ddelisle's Avatar
ddelisle
I always hear riders around town short-shifting these 103's, the 103 is much more efficient at higher RPM's.
I keep the display set to gear/RPM and do glance at it. My upshifts will vary from 3500 - 4800 RPM depending on the situation. I cruise with my RPM's in the power band, basically 2600 RPM and higher and rev-match downshift to always be in the correct gear to stay in the power band. If I'm cruising at 50 MPH I'll be in 3rd gear; 4th is too low and out of the power band, I don't use 6th until 75+ MPH. At 70 MPH in 6th you're right at the bottom of the power band.
One thing, those numbers are all predicated on the fact the bike is fully warmed up. Running a bike hard when they're cold is one of the worst things you can do to them... all those shift points are much lower until she's fully warmed up
Originally Posted by Maxxsmart
Exactly... I'll cruise 70 mph in 5th, and I feel like I have versatility to speed up, or slow down with plenty of power. 6th gear comes in around 75 on the hwy.
Yup, pretty much the same here. 3000-3200 rpm is where she likes to cruise. She just purrs like a kitten, albeit a rabid kitten
Corndog
Jul 18, 2011 12:28 PM
mbjam359
Dec 27, 2007 04:23 PM
rjw54
Jun 3, 2007 05:14 PM
MAX EVO
Jan 17, 2007 01:16 PM
Coyote72
Aug 20, 2006 04:54 PM
