Wide Glide Fender?
Wide Glide Fender?
Hello all. I could not find a good answer to this question.
I have a 2012 Super Glide and am not a fan of the rear fender. Would a 2012 Wide Glide bob tail fender be a direct swap? Maybe I did not describe the rear fender I want for my super glide. I want the same style that comes on the wide glide. I like that chopped turned up look.
Also I am going to install forward controls. Some (Harley) talk about removing the primary and everything where Kuryakyn does not. Is removal necessary?
Thanks for any info you can provide.
I believe the wide glide fender would be too wide. Good news though, your fender is a fairly sought after part. You would likely have no problem trading it for a newer style street bob fender or low rider s. Im pretty sure they went to the chopped fender on the street bobs in 2013. It would be a direct swap.
Also, regarding your second question. Look up the installation instructions on kits you're looking at. You should find your answer pretty easily.
cpl_dvldog (10-20-2016)
