Hex bolt under triple tree
Old Nov 12, 2016 | 10:33 AM
DJY's Avatar
DJY
Default Hex bolt under triple tree
Needing to get loose for new brake line. Any trick or instruction on getting it loose? And yes, I know this may be a dumb question.
Old Nov 12, 2016 | 10:39 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Ummm, turn counter-clockwise?
Old Nov 12, 2016 | 10:43 AM
TinCupChalice's Avatar
TinCupChalice
Yea, that
DJY, those come pretty tight from the factory. Use the appropriate sized allen; sorry, I don't recall the size. Use a short extension and a ratchet; give the ratchet a pop with the palm of your hand and that should break it loose. Don't just try and muscle it off, a quick blow with your hand will break it loose much easier...
Old Nov 12, 2016 | 12:16 PM
Ghost_13's Avatar
Ghost_13
Turn bars to right lock
Install "closed end" wrench over bolt
Use a dead blow hammer to hit wrench and knock bolt loose
Side note
Work out and eat your weaties..., so next time hammer is not necessary
Ghost
Old Nov 12, 2016 | 12:34 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by TinCupChalice
Yea, that
I have to argue your technique, fastest way to strip out an allen socket. Best way to break a stubborn socket head is to apply steady even pressure for a few seconds while holding the tool straight and tight against the bolt. It will resist like it's frozen then suddenly give after a couple seconds . Cannot begin to count the number of rotor bolts I've had un**** for people who went at it your way and rounded them out.......
Old Nov 12, 2016 | 12:44 PM
Ghost_13's Avatar
Ghost_13
Side note
Ghost
Twizted is correct..., and I should have said tap it..., while applying pressure
Or..., use a socket and long breaker bar - then apply steady and ever increasing pressure
Ghost
Old Nov 12, 2016 | 12:46 PM
TinCupChalice
Thanks for that technique upgrade, Twizted! Sounds like I've been getting lucky all these years with my technique As of now, I'll follow your advise when it comes to socket heads
Old Nov 12, 2016 | 12:48 PM
TwiZted Biker
Ghost
Bigger ones I'll use a small drift punch put inside the socket and give a couple raps with a hammer first to shock them a bit and not bugger the socket walls and most come out easier, but smaller 1/4" & 5/16" hardware steady pressure is the way to go. Particularly Torx hardware.....
PS I just added the comment about Torx for those who fought and lost that battle also.
Old Nov 12, 2016 | 01:27 PM
beanoboy's Avatar
beanoboy
Yup pretty sure it's an Allen screw, though maybe they changed after my year 2003...b.
Old Nov 12, 2016 | 02:33 PM
DJY's Avatar
DJY
Thanks
