Clutch Creeping & Hard Shift / Barnett Extra Plate
If I adjust the cable, take up all the free play and then a little more... clutch works perfect, no creeping.
So that's why I think my adjustment in the primary is off because I dont think I should have the cable that tight
Spoke to Barnett.
Get ready for a rant.
Initially I had emailed them, explaining basically my first post. How I adjusted it, the fact its dragging real hard, that if I tighten the cable lots it'll work
They replied "only do 1/4 - 3/8 of a turn loosening" then "did you reuse the stock dampener and seat?"
I replied saying I did reuse cause the instructions said to... i waited a half hour then decided to phone.
I asked why he asked about the seat and dampener.
He says "yaaaa.... you must've received an older kit cause now we don't even supply the narrow friction anymore and state not to reuse the factory spring and seat"
So why isnt that on their website? I think right next to the product it should say something like "UPDATE DO NOT REUSE FACTORY SEAT AND DAMPENER"
Its definitely frustrating
Received 4,299 Likes
Spoke to Barnett.
So you are using the a full width plate with the damper spring and seat installed?
Hey, sounds like you found the problem..
https://www.hdforums.com/forum/touri...rg-issues.html
This thread had the exact same issue. Installed correctly but barnett screwed up
