Clutch Creeping & Hard Shift / Barnett Extra Plate
#31
Barnett Clutch Drag
I have the same problem..
I just want to know if I remove the damper spring and the dished spring can I still run the the smaller diameter clutch plate. Or do I need a full sized plate ?
I know this is an old thread but hopefully my post will help someone who is experiencing the same problems as the original poster. ***ATTENTION*** ***DO NOT REUSE THE SPRING SEAT AND DAMPER WHEN INSTALLING THE BARNETT EXTRA PLATE CLUTCH PACK*** If you reinstalled the spring seat and damper you have to go back in and remove them.
BigGelvis
07-22-2013 03:07 PM
