Clutch Creeping & Hard Shift / Barnett Extra Plate
Hey guys.
I seem to be struggling to understand how to properly adjust the clutch. Ive watched some videos and read lots of threads but what I dont fully understand is where I need to adjust; like the direction.
I installed the Barnett kevlar extra plate kit and HD spring.
I loosened the cable off so there was lots of slack. Loosened jam nut on primary and tightened the rod in (clockwise) until it touched then backed off 3/4 of a turn and tightened the jam nut. Adjusted cable till 1/8" of freeplay. Now when I pop it into gear... its creeping, hard and I have to shut it down to find neutral. If I turn the adjustment on the cable taking away all free play and then some... it'll work but I know that's not right.
So my adjustment on the primary must be wrong... would I need to back it out LESS once touched down to fully disengage the clutch? This is where I'm struggling to understand what to do.
15 FXDF (on mobile so my signature probably wont show up)
Do the whole clutch adjustment procedure again from scratch. Sometimes you have to squeezes the lever a few times to seat the clutch pushrod before it will adjust properly. You should just feel drag when you start backing it out.
On a side note but maybe related....did your clutch plate kit call for you to remove the damper spring and spring seat?
Where is the friction zone?? If it's still out where it's supposed to be then you might have assembled the damping spring / spacer wrong. Did you soak the plates? What about oil level.. Jason idea about popping the lever a couple times is good but screw the center adjuster in 1/2 turn past tight before doing it then see where it backs off to.. If less than 1/2 turn repeat until no change then adjust properly.. I've heard that the +1 kits are known to drag.. Only way I've used them is without the damping spring and a stock thickness wide plate in place of the damping arrangement.. It work well that way but the friction zone can be narrow and the clutch might squawk.
I soaked the plates for a while.
The center adjuster is really sort of a course adjustment to the clutch.. The cables adjustment set where the clutch releases..
It should but not always.. You might want to cut the slack to 1/16 inch and see if it helps.. Also is the clutch lever stock? Some levers reduce length of pull on the cable.
