Low Rider S battery tender lead
Hey all. Those with Low Rider S's, have you figured out how to plug in the battery tender lead that is factory installed under the left side cover without removing the left side cover? There's no opening when the left side cover is mounted to route the lead out. It's a pain in the *** to have to remove the left side cover everytime I want to hook up the battery tender.
Ok so hard to see, but just above my finger you can feed it through, then run it under and I front of your seat on the left side (see pic below) and zip tie it there
Now if it is too short, you can always buy a longer one, and run it through the back of the battery tray, and do the same thing. Then either use the original for something else (cell phone charger or something), or disconnect it all together. Hope this helps.
jcanrun (12-31-2016)
