drag pipes on a 99 FXDWG
I have a nice set of drag pipes for my 99 FXDWG 88cu twin cam, but do you have to adjust any fuel settings or anything when you add drag pipes, i got a set on my older 74 Ironhead and i didnt have to change anything else, but since the Wide Glide is newer i just wanted to make sure it would not affect the running anyways without adding or changing anything.
Thanks in advance
Thanks in advance
If it's a full system, then yes definitely. If they are just slip on pipes, then many will say no, but I'd still recommend it. Anytime you modify anything performance related, it's a good dea to retune/jet carbs. As everyone knows, Harleys run lean as hell from the factory. Lean=heat, heat=unhappy Harley.
Received 4,281 Likes
they technically may not be called "Drag pipes" they are like those in the picture below, (man I love the way his bike looks) , All I know is they are allot louder and even nicer looking then my stock pipes that are on there now
Originally Posted by dougsthang
Here's my 05 after it's latest mods (new 18" rear along with Hog Halter front and rear brakes and rotors)
Save
I don't want to start an argument or be disrespectful, but it is my opinion that this is a bad idea because if you have any problems in the future, you more than likely won't be able to get the exhaust warrantied. Also, it will be a real pain if you make a mistake.
