Advise Needed: Low RIDER S cable length Luck Daves Lucky-13 11" bars
There has to be a reason line manufacturers sell upper and lower brake lines independent of one another. If you are only changing bar height, the question remains why you can't just get the upper ABS line from the master cylinder to the block all by itself? Is there some sort of wizardry required to mate the upper line with the block??
Originally Posted by 17FiXxXeR75
I'm not following. The line from the master cylinder to the block is a single piece. The block is where the lines split off to each side of the dual disk front brake system.
Throttle side is a bit of a pain. If you are going lucky daves bars you shouldn't have to depin connectors. I didn't. I did however crack a connector housing during install and had to order a new piece. Was a pain to wait but an easy fix. You'll have plenty of wire length for signals/controls if you are doing 11". I'm sure you'd be fine at 14". Take pics just in case of screw ups. Removing the tank makes for a much easier job especially come time to stuff wiring back in the neck, just depends whether you are willing to do so. Forum member robbyville did a write up on his bar swap, search for it before your install.
I run WC Slingshots and the connectors were too large to easily internal wire, so I just took a little grinder to make the bottom holes bigger to avoid having to de-pin. Once the holes were opened up it was the easiest internal wire I've ever done.
Gotcha. Heard only upgrade of size without needing longer cables is 10" total.
