2006 FXDB..dual speedos possible
Hi, I was interested in running 2 speedometers, 1 in the center console and 1 on the handlebars like a sportster runs. Is this possible to do if I were to splice the wires and tap in to the speedo wires/harness and run it up to the speedo on the bars.
I've got the Dakota digital and matching flush HD LED gas gauge on the console and tank. I wanted to add the OEM speedo and mount it on the bars...
is the wire splicing a possible option? or is there any other better way to do this.
thanks for your help.
oldbie (03-19-2017)
I would think splicing would be an option. However if it is, you should be able to find some sort of "adapter kit" to make it easier. I assume it would be a jumper harness similar to how the accessory connectors are set up. I think if you have a wiring diagram for the speedo, that will tell you a lot. If you do, post it if you can.
Received 2,189 Likes
Jason Bradford
11-01-2012 05:38 PM
ac
01-26-2010 02:29 PM
