Dyna wheel swap.. safe?
Matt's analysis is correct, but also if you compared the adjusters (along with the swingarm as mentioned above), which is really the item of concern, then you would have seen the same part# from 2008 when the change was made to the mentioned 25mm axle
Using your 2016 example
abez
10-11-2016 11:56 PM
sportncruise
10-30-2008 12:08 PM
