7" Headlight on Street Bob; Nasty Wind in Face
**RESOLVED** 7" Headlight on Street Bob; Nasty Wind in Face
Good afternoon Fellas,
I've read many posts on here regarding the exchange between a 5-3/4" and 7" headlight on a Dyna.
One thing I've never heard anyone mention is the violent pulsating wind that beast of a 7" light puts directly in your face.
I've installed a Harley softail bucket (overpaid, I know), JW Speaker 8700 EVO2 (Got on sale for $225 through 4Wheel Parts), Harley retaining ring, and Harley trim ring.
I am currently using the stock StreetBob headlight mount.
First time out, I noticed a violent pulsating wind directly in my face; Shakes my glasses and rattles my brains.
I thought changing the stock trim ring to a frenched ring, would break up the air a bit; It helped, but not much.
I know, fix it until it's broken... But, it does look bad ***.
Any of you guys out there running a 7" headlight on a Dyna, specifically, StreetBob experience this?
Any idea of a solution?
I am 5-10", 190 lbs, and sitting on a stock seat. I've noticed if I sit up straight and stretch taller, it seems like wind is now at neck level.
I can handle it in the neck and/or chest. But in my face, I get a headache.
I've ordered two new mounting blocks from Headwinds, one will lower approximately 1", and the other will push out 1/4" and lower approximately 1-1/4".
I've searched many sources online for several hours and have not been able to find anything.
Additionally, I've noticed many of the Softail models have a flat piece behind the light on the forks, that are on the same plane as the forks; Not sure if this is technically called a nacelle. Was this put there to create an updraft to help re-direct the air coming off the light up and over the riders head?
Wind Direction Off the Headlight
I had the same problem on my Dyna after I installed a new HID headlight a few years ago. The new bucket was the same diameter but a much longer body than stock. The air coming off the light was evil and after a lot of trial and error, I bought a used Saraceni handlebar bag from a member on this forum who had sold his bike.
The first time I put the bag on the bike and loaded a few items in it, rain gear, the wind pattern changed and went over my head. To this day, if the bag is empty I still get the wind in my face but I never ride any distance like that.
Good luck
www.saracenibags.com
Good luck
I don't think I've ever tried riding it without the bag up front. I might remove it on my way home later to see if there is any difference.
Cannot figure out how to quote prior posts; Obvious above. Clicked multi-quote button, then post. I was not re-directed to the full editor as instructions stated.
Thank you dyna rider and Mid-Night-Rider; I may have to try the tool bag option if my lowered mounting brackets do not help.
Nice bike Mid-Night-Rider.
Thanks Flinter; Your 14" apes are quite a bit taller than my stock minis. I did notice sitting more up right would move the pulsating wind from face to neck/chest.
Nice bike nevil.
I will post pictures of my setup in a bit; So long as I can figure that one out.
Nice bike nevil.
