Installing a tach on '02 FXD.
I'm fixin' to finally put a tach on my Super Glide. Looks fairly straightforward, but I've got a question about the wiring.
Looking at the wiring diagram in my service manual, the tach signal wire is easy enough, but the power & ground wires need to be spliced in to the existing wiring. The ground wire looks like a single splice & then into socket 12 of the main harness connector. Power wire looks like it has to be spliced into both the power wires out of sockets 8 & 9 of the idiot light connector, then into socket 6 of the main harness connector.
Do I have the right of that? Electronics & wiring are voodoo to me, so trying to make sure I'm not a complete stooge.
Any reason I can't just run the ground wire to the frame & bypass having to splice into the harness?
Any recommendations on how to splice the wires? I avoid hacking into wiring like the plague & while I've got a decent soldering iron & can solder reasonably well, but if left to my own devices I'll find absolutely the wrong way to do it.
Tools? I was eye-balling this crimper- . Is this the right crimper for those wonky Deutsch connectors?
At any rate, any tips/advice would be hugely appreciated.
Received 4,297 Likes
firstrock
08-06-2012 03:45 PM
