2017 FXDLS ECM Update - Clicking Under the Fuel Tank
I took my new FXDLS in for the 1K service and they mentioned they had to do a recall update to the ECM. Now, when I turn on the ignition switch there is a single click that comes from under the gas tank. It sounds like a relay engaging. When I turn the ignition switch off, it clicks one time again. Anybody know what this is?
Same here. Click is the ACRs opening before the starter engages. Previously they weren't opening early enough and causing the hard start issues. I wouldn't think you should not hear them click when shutting the bike down though. Their sole purpose is to release compression when starting the motor. When running, they are closed and stay that way until you power on prior to startup. If they stayed open, you're losing compression
My thoughts exactly! O.P. should probably talk with the Service Dept. at Harley - something ain't right, if what is described is true (I.e. a 2nd loud click from the same valve when turning off the motor).
I have not had the ECM update done on my LRS.
Best wishes...
NE RIDER
11-10-2012 02:26 PM
